Product
Seagate Expansion 500GB USB 3.0 2.5" Portable Hard Drive
Quicklinx: B7NCWS00 Mfr#: STEA500400
Form Factor: 2.5"
Capacity: 500GB
Interface: USB 3.0
More than 50 in stock
£38.14 ex VAT
£45.76 inc VAT
Simple add-on storage that goes with you
The Seagate Expansion Portable hard drive offers an easy-to-use solution when you need to instantly add storage to your computer and take files on the go.
- Drag and drop file saving, right out of the box
- USB powered
- Fast data transfer with USB 3.0 connectivity
The easy-to-use storage solution
The Expansion portable hard drive can be installed easily by plugging in a single USB cord. You can start saving your digital files to this external hard drive within seconds of removing it from the box.
Instantly adds storage capacity
Digital photos, videos and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity. The Expansion portable hard drive features a range of capacities, with the 1TB model offering enough data storage for:
- Up to 1,000 hours of digital video
- Up to 250 two-hour DVD films
- Up to 320,000 digital photos
- Up to 16,660 hours of digital music
Installs in seconds
Seagate® Expansion™ portable hard drive features make it incredibly easy to use this drive right from the box.
- Simply plug the included USB cable into your computer - no external power supply is needed.
- The drive is automatically recognised by the Windows operating system - no software to install and nothing to configure.
- Drag and drop to save files to the Expansion portable drive.
- Built-in power management automatically ensures energy-efficient operation
What's In the Box?
- Expansion Portable hard drive
- USB 3.0 cable
- Quick start guide
Seagate Expansion STEA500400 - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
80 mm x 117 mm x 14.8 mm
170 g
Worldwide
500 GB
USB 3.0
80 mm
117 mm
14.8 mm
170 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows 7, Windows 8
1 x USB 3.0 cable - external - 46 cm
Worldwide
Shipping Width
103 mm
Shipping Depth
140 mm
Shipping Height
31 mm
Shipping Weight
260 g
Form Factor: 2.5"
Capacity: 500GB
Interface: USB 3.0
Brand: Seagate
Price Range Ex VAT: 0 - 50
