Seagate Expansion 2TB USB 3.0 2.5" Portable Hard Drive
Quicklinx: B8NDWS00 Mfr#: STEA2000400
Form Factor: 2.5"
Capacity: 2TB
Interface: USB 3.0
More than 50 in stock
£53.46 ex VAT
£64.15 inc VAT
The Seagate Expansion portable drive is compact and perfect for taking with you on the go. Add more storage space to your computer instantly and take large files with you when you travel.
Set-up is straightforward: simply connect a single USB cable and you are ready to go. The drive is powered from the USB cable, so there is no need for an external power supply. Also, it is automatically recognized by the Windows operating system, so there is no software to install and nothing to configure. Saving files is easy - simply drag and drop.
Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backward compatible with USB 2.0 for additional system compatibility.
Seagate Expansion STEA2000400 - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
80 mm x 117 mm x 14.8 mm
170 g
Worldwide
2 TB
USB 3.0
80 mm
117 mm
14.8 mm
170 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
1 x USB 3.0 cable - external - 46 cm
Worldwide
Shipping Width
103 mm
Shipping Depth
140 mm
Shipping Height
31 mm
Shipping Weight
260 g
Form Factor: 2.5"
Capacity: 2TB
Interface: USB 3.0
Brand: Seagate
Price Range Ex VAT: 50 - 100
