Seagate Exos X16 ST16000NM002G Hard drive 16TB SAS 12Gb/s
Quicklinx: FG5NWS00 Mfr#: ST16000NM002G
Seagate manufactures hard drives that specifically address the needs of the hyperscale storage market. As the flagship of the Seagate X class, the Exos X16 enterprise hard drives are the highest-capacity hard drives in the fleet.
Seagate Exos X16 ST16000NM002G - hard drive - 16 TB - SAS 12Gb/s
Hard drive - internal
16 TB
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
PowerChoice, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, advanced format 4Kn, Organic Solderability Preservative, Seagate Fast Format, Helium Sealed-Drive Design
101.85 mm x 147 mm x 26.11 mm
670 g
5-year warranty
16 TB
SAS 12Gb/s
Buffer Size
256 MB
101.85 mm
147 mm
26.11 mm
670 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
261 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Power Consumption
5 Watt (idle) , 10.2 Watt (maximum) , 6.2 Watt (random read/write)
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
50 g @ 2 ms
Shock Tolerance (non-operating)
200 g @ 2 ms
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
