Seagate Exos 6TB E-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Quicklinx: D73BWS00 Mfr#: ST6000NM0115
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 6TB
Spin Speed (rpm): 7200rpm
£187.78 ex VAT
£225.33 inc VAT
Supporting the industry's best response times for an 8TB nearline drive, Seagate's Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to our comprehensive advanced caching technology. When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Maximum capacity and built for speed
  • World-class reliability meets high-capacity
    When building maximum density server and storage solutions with Seagate's 8TB Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Reliable, robust bulk data Storage for a 24 x 7 world
    High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550TB per year, which is up to 10x the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs.
Seagate Exos 7E8 ST6000NM0115 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal - Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, advanced format 512e, 24x7 availability, Advanced Write Caching
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.85 mm x 147 mm x 26.1 mm
705 g
5-year warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
705 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
226 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.25 Watt (idle) , 8.31 Watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
Type: Hard drive
Capacity: 6TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
