Seagate Exos 300GB E-Class Mission Critical 10000RPM 2.5" 128MB Hard Drive
Quicklinx: D74QWS00 Mfr#: ST300MM0048
Form Factor: 2.5"
Type: Hard drive
Interface Type: SAS
Capacity: 300GB
Spin Speed (rpm): 10000rpm
More than 50 in stock
£88.38 ex VAT
£106.05 inc VAT
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
  • Perfect match of high capacity and high performance
    The high capacity and small 2.5-inch footprint of the Exos 10E2400 drive enables data centers to keep pace with data growth and optimize data center real estate. The Seagate Enhanced Caching feature accelerates read and write I/O operations, preventing applications from slowing down under peak usage conditions.
  • Maximize storage investments for the long haul
    Exos 10E2400 offers Protection Information (PI) to help protect against data corruption, and Seagate PowerChoice technology for T10-compliant power management enables IT organizations to tailor systems for enhanced power consumption. RAID recovery is faster and safer with the help of the Seagate RAID Rebuild technology option.
Seagate Exos 10E2400 ST300MM0048 - hard drive - 300 GB - SAS 12Gb/s
Hard drive - internal
300 GB
2.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
10000 rpm
PowerChoice, Protection Information (PI), Seagate RAID Rebuild, advanced format 512n
70.1 mm x 100.45 mm x 15 mm
218 g
5-year warranty
300 GB
2.5"
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
70.1 mm
100.45 mm
15 mm
218 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
215 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
SAS 12 Gb/s
Compatible Bay
2.5"
Power Consumption
6.3 Watt (active) , 3.09 Watt (idle)
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 0-500 Hz
Vibration Tolerance (non-operating)
3 g @ 0-500 Hz
Form Factor: 2.5"
Type: Hard drive
Interface Type: SAS
Capacity: 300GB
Brand: Seagate
Stock Status: In stock
