Seagate Exos 2TB E-Class Nearline Enterprise 7200RPM 2.5" 128MB Hard Drive
Quicklinx: D74HWS00 Mfr#: ST2000NX0273
Form Factor: 2.5" SFF
Type: Hard drive
Interface Type: SAS
Capacity: 2TB
Spin Speed (rpm): 7200rpm
£226.74 ex VAT
£272.08 inc VAT
The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering high capacities and enterprise reliability at the industry's lowest power per watt for storage-hungry nearline applications.
The Enterprise Capacity 2.5 HDDs reduce per-gigabyte cooling and energy costs by packing high capacities into an SFF, low-power-consumption drive.
The Enterprise Capacity 2.5 HDDs can help you deploy additional enterprise storage without expanding your data center.
Seagate Exos 7E2000 ST2000NX0273 - hard drive - 2 TB - SAS 12Gb/s -
Hard drive - internal - nearline - PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen
2 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
70.1 mm x 100.45 mm x 15 mm
198 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
2 TB
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
70.1 mm
100.45 mm
15 mm
198 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
136 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
3.53 Watt (idle) , 6.02 Watt (read) , 1.52 Watt (standby)
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance (operating)
25 g @ 2 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 5-500 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Type: Hard drive
Interface Type: SAS
Capacity: 2TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
