The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering high capacities and enterprise reliability at the industry's lowest power per watt for storage-hungry nearline applications.
The Enterprise Capacity 2.5 HDDs reduce per-gigabyte cooling and energy costs by packing high capacities into an SFF, low-power-consumption drive.
The Enterprise Capacity 2.5 HDDs can help you deploy additional enterprise storage without expanding your data center.
- Seagate Exos 7E2000 ST2000NX0273 - hard drive - 2 TB - SAS 12Gb/s
- Hard drive - internal - nearline - PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen
- Capacity
- 2 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- 70.1 mm x 100.45 mm x 15 mm
- 198 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 2 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- 70.1 mm
- 100.45 mm
- 15 mm
- 198 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 136 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,400,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 2 x SAS 12 Gb/s
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 3.53 Watt (idle) , 6.02 Watt (read) , 1.52 Watt (standby)
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance (operating)
- 25 g @ 2 ms
- Shock Tolerance (non-operating)
- 400 g @ 2 ms
- Vibration Tolerance (operating)
- 0.5 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 5-500 Hz
