Product
Seagate Exos 1TB E-Class Nearline Enterprise 7200RPM 3.5" 128MB Hard Drive
Quicklinx: D74DWS00 Mfr#: ST1000NM0045
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: SAS
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£75.26 ex VAT
£90.31 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Seagate's Enterprise Capacity 3.5 HDD enables the ultra-fast data transfers thanks to the comprehensive advanced caching technology. Meet your storage workload requirements in the efficient and cost-effective data center footprint. With user-definable innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you have the control to tailor your bulk storage requirements for even greater improvements in lowering your total cost of ownership.
  • Maximum capacity built for speed
  • World-class reliability meets high capacity
    When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Reliable, robust bulk data storage for a 24/7 world
    High-capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs.
Seagate Exos 7E8 ST1000NM0045 - hard drive - 1 TB - SAS 12Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Super Parity, T10 Data Integrity Field (DIF), 24x7 availability, advanced format 512n
101.85 mm x 147 mm x 26.1 mm
610 g
5 years warranty
1 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
610 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
215 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
4.75 Watt (idle) , 6.3 Watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
Type: Hard drive
Interface Type: SAS
Capacity: 1TB
Capacity: 1TB
Brand: Seagate
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
