Product
Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Quicklinx: D73JWS00 Mfr#: ST12000NM0027
Form Factor: 3.5"
Type: Hard drive
Interface Type: SAS
Capacity: 12TB
Spin Speed (rpm): 7200rpm
12 in stock
£326.01 ex VAT
£391.21 inc VAT
Marketing description is not available.
Seagate Exos X12 ST12000NM0027 - hard drive - 12 TB - SAS 12Gb/s
Hard drive - internal
12 TB
3.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Seagate Secure, PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.6 mm x 147 mm x 26.11 mm
650 g
5 years warranty
12 TB
3.5"
SAS 12Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.6 mm
147 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
261 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5"
Power Consumption
5.5 Watt (idle) , 9.3 Watt (active)
Limited warranty - 5 years
5 °C
60 °C
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
Form Factor: 3.5"
Type: Hard drive
Interface Type: SAS
Capacity: 12TB
Brand: Seagate
Price Range Ex VAT: 300 - 500
