Seagate Exos 12TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Quicklinx: D737WS00 Mfr#: ST12000NM0007
Marketing description is not available.
Seagate Exos X12 ST12000NM0007 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Seagate Secure, PowerChoice, Seagate RAID Rebuild, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.6 mm x 147 mm x 26.11 mm
650 g
5-year warranty
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.6 mm
147 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
261 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5 Watt (idle) , 7.8 Watt (active)
Limited warranty - 5 years
5 °C
60 °C
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
