Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Quicklinx: D73KWS00 Mfr#: ST10000NM0096
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: SAS
Capacity: 10TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£251.86 ex VAT
£302.23 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
The Seagate Enterprise Capacity 3.5 HDD (Helium) lets you turbocharge data transfers with dependably fast read/write performance. Meet your workload requirements while minimizing your data center footprint. Manage increasing volumes of data in cloud data centers much faster thanks to advanced write caching algorithms.
  • Built for speed - right where it's needed
  • Minimal TCO, maximum MTBF
    Dramatically reduce IOPS/watt while improving rack density thanks to low drive weight.
  • Designed for reliability
    A host of engineering innovations ensures a better hermetically sealed - and so much more dependable - drive. Premium materials, including a wrought-aluminum base, gas-impermeable enclosure, and wide-weld sealed drive design ensure maximum reliability. Humidity sensor and corrosion protection offer increased resistance to harsh environments.
Seagate Exos X10 ST10000NM0096 - hard drive - 10 TB - SAS 12Gb/s
Hard drive - internal - temperature sensor, Enterprise Class Reliability, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, 24x7 availability, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
10 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Temperature sensor, Enterprise Class Reliability, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, 24x7 availability, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, Advanced Write Caching
101.85 mm x 147 mm x 26.11 mm
650 g
5-year warranty
10 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
256 MB
101.85 mm
147 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
249 MBps
4KB Random Read
170 IOPS
4KB Random Write
370 IOPS
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
5.5 Watt (idle) , 9 Watt (write) , 9.4 Watt (random read)
Limited warranty - 5 years
5 °C
60 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
Type: Hard drive
Interface Type: SAS
Capacity: 10TB
Brand: Seagate
Stock Status: Clearance
Price Range Ex VAT: 150 - 300
