Seagate Enterprise Performance 300GB 15000 rpm SAS 12Gb/s
Quicklinx: CT51WS00 Mfr#: ST300MP0005
The Savvio 15K.3 drive enables Tier 1 applications to read and write both random and sequential data faster. Data centers can store and access important random data up to 10% faster and sequential data up to 21% faster over previous generations, enabling them to process more transactions within a given time period.
Providing up to 300 GB capacity, the Seagate Savvio 15K.3 drive stores twice the amount of data without increasing the total number hard drives used. This helps data centers keep up with the growth of data while improving storage efficiency.
The Savvio 15K.3 drive provides protection information and self-encrypting drive options to help companies achieve corporate and/or government security compliance goals. The drive helps protect data from inadvertent change from the moment of creation until the end of life, and from exposure if the device is lost, stolen or retired.
  • Improves performance
  • Doubles capacity
  • Protects data
Seagate Enterprise Performance 15K HDD ST300MP0005 - hard drive - 300 GB - SAS 12Gb/s
Hard drive - internal
300 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
15000 rpm
69.85 mm x 100.45 mm x 15 mm
225 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
300 GB
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
69.85 mm
100.45 mm
15 mm
225 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
233 MBps
Average Latency
2 ms
Spindle Speed
15000 rpm
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
8.4 Watt (active) , 4.8 Watt (idle)
Limited warranty - 5 years
5 °C
55 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g
Vibration Tolerance (non-operating)
2.4 g
