The Seagate Enterprise Capacity 2.5 HDD is the only 2.5-inch enterprise-class hard drive delivering both, capacities and enterprise reliability at the industry's lowest power per Watt for storage-hungry near-line applications.
Unparalleled HDD power savings
Enterprise Capacity 2.5 HDDs reduce per-gigabyte cooling and energy costs by packing high capacities into an SFF, low-power-consumption drive. Included Seagate PowerChoice technology can further reduce energy costs by empowering IT organizations to tailor systems for optimal performance and power consumption. This results in power savings of up to 54% over traditional 3.5 - inch drives, and potentially operating at less than 1 Watt when idle. PowerChoice is based on the T10-compliant power management standard. -
Big storage for small spaces
Enterprise Capacity 2.5 HDDs can help you deploy additional enterprise storage without expanding your data center. This model can help you store many data in the same footprint.
- Seagate Exos 7E2000 ST1000NX0323 - hard drive - 1 TB - SAS 12Gb/s
- Hard drive - internal - nearline
- Capacity
- 1 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- PowerChoice, Secure Drive, Seagate RAID Rebuild, Low Halogen
- 70.1 mm x 100.45 mm x 15 mm
- 190 g
- 5-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 70.1 mm
- 100.45 mm
- 15 mm
- 190 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 136 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,400,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 2 x SAS 12 Gb/s
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 3.29 Watt (idle) , 5.9 Watt (read) , 1.52 Watt (standby)
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance (operating)
- 25 g @ 2 ms
- Shock Tolerance (non-operating)
- 400 g @ 2 ms
- Vibration Tolerance (operating)
- 0.5 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 5-500 Hz
