Seventh-generation Seagate Cheetah 15K.7 drive is the fastest, highest capacity and most reliable ever. Lower watts/GB ratio helps achieve reduced power and cooling costs while optimizing capacity requirements. Higher performance with fewer drives - reducing support infrastructure, physical space requirements and storage management costs. The highest reliability of any 3.5-inch drive, with increased system reliability due to the need for fewer drives.
Lowest cost of ownership
Seventh-generation Seagate Cheetah 15K.7 drive is the fastest, highest capacity and most reliable ever. Lower watts/GB ratio helps achieve reduced power and cooling costs while optimizing capacity requirements. Higher performance with fewer drives - reducing support infrastructure, physical space requirements and storage management costs. The highest reliability of any 3.5-inch drive, with increased system reliability due to the need for fewer drives. -
Highest reliability
Seagate continues to focus on reliability and data protection. MTBF is an industry-leading 1.6 million hours. Seagate-exclusive enhanced error correction code better maintains performance throughout the life of the drive and reduces the probability of lost data. The third generation of Seagate-exclusive background media scan proactively scans the media for potential defects during drive idle time. It enables incipient errors to be corrected before data is lost. Quick and robust download feature loads firmware in seconds, with built-in protection to ensure no corruption in the event of a power failure during firmware switch.
- Seagate Cheetah 15K ST3300657SS - hard drive - 300 GB - SAS 6Gb/s
- Hard drive - internal
- Capacity
- 300 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 15000 rpm
- Enhanced Error Correction Code, Background Media Scan (BMS), PowerTrim technology, Perpendicular Magnetic Recording (PMR)
- 10.2 cm x 14.7 cm x 2.5 cm
- 0.67 kg
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 300 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 6Gb/s
- Buffer Size
- 16 MB
- 10.2 cm
- 14.7 cm
- 2.5 cm
- 0.67 kg
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 296 MBps
- Seek Time
- 3.4 ms (average)
- Track-to-Track Seek Time
- 0.2 ms
- Average Latency
- 2 ms
- Spindle Speed
- 15000 rpm
Reliability
- MTBF
- 1,600,000 hours
- Non-Recoverable Errors
- 1 per 10^16
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance
- 60 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
- Vibration Tolerance
- 1 g @ 5-400 Hz (operating) / 3 g @ 5-400 Hz (non-operating)
