Product
Seagate 8TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
Quicklinx: CH00WS00 Mfr#: ST8000VX0022
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 8TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£183.96 ex VAT
£220.75 inc VAT
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST8000VX0022 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
RV Sensor, 24x7 availability
101.85 mm x 146.99 mm x 26.11 mm
780 g
3 years warranty
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
2 Watt (start) , 9 Watt (active) , 7.6 Watt (idle) , 0.6 Watt (sleep) , 0.6 Watt (standby)
Limited warranty - 3 years
5 °C
70 °C
Form Factor: 3.5"
Type: Hard drive
Capacity: 8TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
