Seagate 8TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9XJWS00 Mfr#: ST8000NE0004
Form Factor: 3.5"
Type: Hard drive
Capacity: 8TB
Spin Speed (rpm): 7200rpm
Select:
£212.61 ex VAT
£255.13 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
IronWolf Pro is designed for everything business NAS. Get used to tough, ready and scalable 24 x 7 performance that can handle multi-drive environments.
  • Optimized for NAS with AgileArray
    AgileArray is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible.
  • High performance means reduced lag times
    High performance means reduced lag times or downtime for users during high traffic time for the NAS. Seagate leads the competition with the highest performance in NAS-class drives.
  • Seagate rescue data recovery
    IronWolf Pro comes with extra peace of mind for any mechanical, accidental or natural disaster. With a 90% success rate of in-house recovery, Seagate has your back with a rescue data recovery plan.
  • Rotational Vibration (RV) mitigation
    IronWolf Pro comes standard with RV sensors to maintain high performance in multi-bay NAS enclosures.
  • Do more with multi-user technology
    Enables user workload rate. Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business.
  • Designed for always on, always accessible 24 x 7 performance
    Access your data on your NAS any time, remotely or on site.
Seagate IronWolf Pro ST8000NE0004 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal - Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.85 mm x 146.99 mm x 26.11 mm
650 g
5-year warranty
Bundled with
Seagate Rescue Data Recovery
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
650 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
2 Watt (start) , 4.4 Watt (idle) , 6.8 Watt (average) , 0.8 Watt (standby) , 0.8 Watt (sleep)
NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years , Technical support - data recovery - 2 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 8TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
