Product
Seagate 8TB IronWolf 3.5" SATA 6Gb/s 7200RPM 256MB Hard Drive
Quicklinx: CGZRWS00 Mfr#: ST8000VN0022
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 8TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£191.04 ex VAT
£229.24 inc VAT
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST8000VN0022 - hard drive - 8 TB - SATA 6Gb/s
Hard drive
8 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
101.6 mm x 146.99 mm x 26.11 mm
780 g
3 years warranty
Hard drive
8 TB
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
9 Watt (active) , 7.2 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep)
Limited warranty - 3 years
5 °C
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
20 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Type: Hard drive
Capacity: 8TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
