Seagate 8TB Game Drive Hub for Xbox
Quicklinx: CYV0WS00 Mfr#: STGG8000400
Form Factor: 3.5"
Capacity: 8TB
£133.62 ex VAT
£160.34 inc VAT
WithThe Game Drive Hub for Xbox allows you to stretch out with a colossal 8 TB — plenty of room to install 200+ games. Easily take care of your game storage needs and make deleting old games a thing of the past. Plus, all that extra space is useful for the sizeable game-save data and downloadable content you’ll want to hold on to.
  • Dual quick-access USB 3.0 ports
    Two front-facing USB 3.0 ports make it super convenient to charge your controllers and mobile devices.
  • Easy plug-and-play setup
    Setup can be completed in minutes. Just connect your drive to any of your Xbox One's USB ports, and the console will walk you through the simple installation.
  • Seamless gaming performance and experience
    Game Drive Hub for Xbox connects by high-speed USB 3.0, which gives you full gaming performance - like playing from your console's hard drive.
  • Keep your universe of games together
    With a large capacity you can keep all of your games in one place.
Seagate Game Drive Hub for Xbox STGG8000400 - hard drive - 8 TB - USB 3.0
Hard drive - external (portable) - built-in USB hub
8 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Built-in USB hub
Power Source
USB bus
Enclosure Colour
White
41 mm x 198.11 mm x 118 mm
0.89 kg
Worldwide
1-year warranty
8 TB
USB 3.0
Built-in USB hub
41 mm
198.11 mm
118 mm
0.89 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
2 x USB 3.0
Power Source
USB bus
1 x USB 3.0 cable - external - 1.2 m
Enclosure Colour
White
Worldwide
Limited warranty - 1 year
Form Factor: 3.5"
Capacity: 8TB
Brand: Seagate
Price Range Ex VAT: 100 - 150
