Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO.
Impressive capacity - designed for speed
Supporting the industry's best response times for an 8TB a nearline drive, the Seagate Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market. With innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you can customize your bulk storage requirements for even greater improvements in your TCO. -
World-class reliability meets high-capacity
When building maximum density server and storage solutions with the 8TB Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs, while offering your users a consistent and predictable response rate. -
Reliable, robust bulk data storage for a 24×7 world
High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550TB per year, which is up to 10× the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs. Choose from 12Gb/s SAS or SATA 6Gb/s interfaces for easy integration into existing platforms. -
Protect data with SED options
Enterprise Capacity 3.5 HDD protects data where it lives - on the drive.
- Seagate Exos 7E8 ST8000NM0055 - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- PowerChoice, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Power Balance technology, advanced format 512e, 24x7 availability
- 101.85 mm x 147 mm x 26.1 mm
- 780 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 237 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9 Watt (idle) , 10 Watt (read)
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Vibration Tolerance (non-operating)
- 5 g @ 10-500 Hz
