Seagate 8TB BarraCuda SATA 6GB/s 3.5" Drive
Quicklinx: D9X0WS00 Mfr#: ST8000DM004
Select:
  • 8TB
The Barracuda family has earned awards and accolades around the globe. This is because Seagate has demonstrated a commitment to introduce technologies that allow people to work faster, do more, and feel great about making an investment in proven technology. And, for those who want the biggest, high performance drive available, the Barracuda choice is without peer.
Versatile. Fast. Dependable
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. With drives available up to 12 TB, the BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads. BarraCuda Pro also comes equipped with a 5-year limited warranty.
3.5-Inch BarraCuda Hard Drives Deliver
Rock-solid reliability built on over 20 years of BarraCuda innovation. Versatile mix of capacity and price point options to fit any budget. Multi-Tier Caching Technologyâ„¢ for excellent hard drive performance.
All hard drives in the BarraCuda family come equipped with Multi-Tier Caching Technology (MTC). MTC takes your PC to new performance levels, so you can load applications and files faster than ever before. By applying intelligent layers of NAND Flash, DRAM and media cache technologies, BarraCuda delivers improved read and write performance by optimising data flow.
  • Versatile HDDs for all your PC needs bring you industry-leading excellence in personal computing.
  • For over 20 years the BarraCuda family has delivered super-reliable storage for the hard drive industry.
  • Capacities up to 8 TB for desktops, BarraCuda leads the market with the widest range of storage options available.
  • Advanced Power modes help save energy without sacrificing performance.
  • SATA 6 Gb/s interface optimises burst performance.
Seagate Barracuda ST8000DM004 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Native Command Queuing (NCQ), PIO mode 0-4 support, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.1 mm
630 g
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.1 mm
630 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps
Average Latency
6 ms
Reliability
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.3 Watt (read) , 3.4 Watt (idle) , 5.3 Watt (write) , 0.25 Watt (standby) , 0.25 Watt (sleep)
Software Included
Seagate SeaTools
RoHS, China RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90%
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
