Seagate 6TB SkyHawk 3.5" SATA 6Gb/s 256MB Surveillance Hard Drive
Quicklinx: CH01WS00 Mfr#: ST6000VX0023
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 6TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£139.71 ex VAT
£167.65 inc VAT
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST6000VX0023 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal - RV Sensor, 24x7 availability, ImagePerfect firmware
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.85 mm x 146.99 mm x 26.11 mm
705 g
3-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
705 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
195 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
2 Watt (start) , 9 Watt (active) , 7.2 Watt (idle) , 0.6 Watt (sleep) , 0.6 Watt (standby)
Limited warranty - 3 years
5 °C
70 °C
Form Factor: 3.5"
Type: Hard drive
Capacity: 6TB
Brand: Seagate
Price Range Ex VAT: 100 - 150
