Seagate 6TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9XGWS00 Mfr#: ST6000NE0023
Select:
  • 6TB
IronWolf Pro is designed for everything business NAS. Get used to tough, ready and scalable 24 x 7 performance that can handle multi-drive environments.
  • Optimized for NAS with AgileArray
    AgileArray is built for dual-plane balancing and RAID optimization in multi-bay environments with the advanced power management.
  • High performance means reduced lag times
    High performance means reduced lag times or downtime for users during high traffic time for the NAS.
  • Rotational Vibration (RV) mitigation
    IronWolf Pro comes standard with RV sensors to maintain high performance in multi-bay NAS enclosures.
  • Do more with multi-user technology
    Enables user workload rate. Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business.
Seagate IronWolf Pro ST6000NE0023 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
24x7 continuous operation, Hot-Plug Support, rotation vibration sensor, AgileArray
101.85 mm x 146.99 mm x 26.11 mm
705 g
5-year warranty
Bundled with
Seagate Rescue Data Recovery
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
705 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
ICES-003 Class B, NMB-3 Class B
Limited warranty - 5 years , Insurance - data recovery - 2 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (non-operating)
5 g @ 10-500 Hz
