Seagate 6TB Archive HDD 3.5" SATA 6Gb/s 128MB Hard Drive
Quicklinx: BM7MWS00 Mfr#: ST6000AS0002
The Seagate Enterprise NAS HDD is designed to combine industry-leading capacity with reliability and performance. Designed for mid-range enterprise and private cloud environments, this NAS HDD delivers sustained performance for global availability and 24×7 accessibility.
  • Industry-leading drive capacity
    The high-performance Enterprise NAS HDD is available in a single NAS drive, helping to lower the total cost of ownership by using fewer drives and rackmount systems.
  • Maximized reliability for your critical data
    Reliability has never been more important to your business. The Enterprise NAS HDD has more reliability features and options that help to ensure your data is safe.
  • Seriously robust performance
    NAS environments demand a unique combination of performance and reliability. Designed for performance with workgroups of more than 25 users, the Enterprise NAS HDD includes higher write workloads for NAS-optimized performance, RV sensor for drive head control and vibration control and 3D motor balancing for optimum performance in multi-drive solutions.
  • Best-fit enterprise NAS applications
    Global business ecosystems require data agility for collaboration. Ideal for environments that require 24×7 availability and accessibility, the Enterprise NAS HDD is designed to manage aggressive workloads in enterprise environments.
Seagate Archive HDD ST6000AS0002 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Native Command Queuing (NCQ), Halogen Free, Advanced Format technology, PowerChoice, Seagate AcuTrac technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.11 mm
780 g
3-year warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps (read) / 150 MBps (write)
Reliability
MTBF
800,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.5 Watt (active) , 5 Watt (idle) , 1 Watt (standby) , 1 Watt (sleep)
Software Included
Seagate SeaTools
RoHS
Limited warranty - 3 years
60 °C
