Your basket is empty
Seagate 6TB Archive HDD 3.5" SATA 6Gb/s 128MB Hard Drive
Quicklinx: BM7MWS00 Mfr#: ST6000AS0002
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 6TB
Stock Status: Clearance
Hurry, only 1 left in stock!
£151.24 ex VAT
£181.48 inc VAT
The Seagate Enterprise NAS HDD is designed to combine industry-leading capacity with reliability and performance. Designed for mid-range enterprise and private cloud environments, this NAS HDD delivers sustained performance for global availability and 24×7 accessibility.
Seagate Archive HDD ST6000AS0002 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Native Command Queuing (NCQ), Halogen Free, Advanced Format technology, PowerChoice, Seagate AcuTrac technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.11 mm
780 g
3 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps (read) / 150 MBps (write)
Reliability
MTBF
800,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
7.5 Watt (active) , 5 Watt (idle) , 1 Watt (standby) , 1 Watt (sleep)
Software Included
Seagate SeaTools
RoHS
Limited warranty - 3 years
60 °C
Seagate 6TB Archive HDD 3.5 Bundle deal on Seagate 6TB Archive HDD 3.5" SATA 6Gb/s 128MB Hard Drive
£167.25
saving £6.92
Cables
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.39 | in stock
£153.94
saving £2.70
Type: Hard drive
Capacity: 6TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
