The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Maximize storage investments for the long haul
Exos 10E2400 offers protection information to help protect against data corruption. RAID recovery is faster and safer. -
Superior data security features
With instant secure erase, drive retirement is safe, fast and cost effective.
- Seagate Exos 10E2400 ST600MM0218 - hard drive - 600 GB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 600 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES-XTS
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 10000 rpm
- Idle Read After Write (IRAW), PowerChoice, Error Correction Code (ECC), Seagate RAID Rebuild, LED status indicator, Dual Port, upgradable firmware, advanced format 512n, Drive Self Test (DST), S.M.A.R.T.
- 70.1 mm x 100.45 mm x 15 mm
- 222 g
- 5-year warranty
- Capacity
- 600 GB
- 256-bit AES-XTS
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 70.1 mm
- 100.45 mm
- 15 mm
- 222 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 215 MBps
- Average Latency
- 2.9 ms
- Spindle Speed
- 10000 rpm
Reliability
- MTBF
- 2,000,000 hours
- Recoverable Errors
- 10 per 10^12
- Non-Recoverable Errors
- 1 per 10^16
- Seek Errors
- 10 per 10^8
Expansion & Connectivity
- 2 x SAS 12 Gb/s - 29 pin internal SAS (SFF-8482)
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 6.68 Watt (active) , 3.44 Watt (idle)
- ICES-003, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ISO 7779, KCC KN22, KCC KN24, cUL No.60950-1, China RoHS, AS/NZS CISPR 22, RCM, EMI/EMS Class B, CAN/CSA-CISPR 22-10, FCC Part 15 Class B, ACMA, EN 62368-1, IEC 62368-1
- Limited warranty - 5 years
- 5 °C
- 55 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 11 ms
- Shock Tolerance (non-operating)
- 400 g @ 2 ms
- Vibration Tolerance (operating)
- 0.5 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 5-500 Hz
- Sound Emission
- 24 dB
