The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by 30 years of trusted performance, reliability and simplicity.
Maximize hard drive storage densities
Seagate Desktop HDD, 1TB-per-disk technology incorporates 340,000 unique tracks in the width of a single inch. This incredible storage density drives new capacity possibilities and lowers your total storage costs. -
AcuTrac technology
Seagate AcuTrac technology enables storage densities with accurate reading and writing to nano-sized tracks that are only 75 nanometers wide! That's about 1/500th the size of the period at the end of this sentence.
- Seagate Desktop HDD ST5000DM002 - hard drive - 5 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 5 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Native Command Queuing (NCQ), Halogen Free, Seagate OptiCache technology, Seagate AcuTrac technology, Seagate SmartAlign technology, TGMR recording technology, advanced format 512e, S.M.A.R.T.
- 101.6 mm x 146.99 mm x 26.11 mm
- 780 g
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Capacity
- 5 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 101.6 mm
- 146.99 mm
- 26.11 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 220 MBps (read) / 180 MBps (write)
- Seek Time
- 8.5 ms (average)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 4 ms
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9 Watt (active) , 7.2 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep) , 2 Watt (start)
- Software Included
- DiscWizard
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90% (non-condensing)
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 300 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 3 g @ 22-350 Hz
