The stunning Seagate Seven portable drive celebrates over 35 years of storage expertise and innovation. This statement product exemplifies advanced storage R&D uniting with world-class industrial design to create the slimmest way to carry 500GB of data. The Seagate Seven enclosure is made entirely of steel, not only to achieve the thinnest external drive, but also for a premium appearance inspired by a bare drive, the essence of storage. The superior experience is extended to the included USB 3.0 cable, a stylish, premium braided design instead of the standard cable found with most external drives. Since the drive is bus powered, meaning it draws power directly from the USB port, and does not require an external power supply, the Seagate Seven is perfect for those on-the-go situations. Push the limits of possible with the thinnest portable drive, Seagate Seven.
- Seagate Seven STDZ500400 - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- Enclosure Colour
- Silver
- 82 mm x 122.5 mm x 7 mm
- 90 g
- 3-year warranty
- Capacity
- 500 GB
- Interface
- USB 3.0
- 82 mm
- 122.5 mm
- 7 mm
- 90 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- Seagate Dashboard
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - external - 45.72 cm
- Enclosure Colour
- Silver
- Limited warranty - 3 years
