Your basket is empty
Seagate 500GB Seven Ultra Slim USB 3.0 Portable Drive
Quicklinx: B1SLWS00 Mfr#: STDZ500400
The stunning Seagate Seven portable drive celebrates over 35 years of storage expertise and innovation. This statement product exemplifies advanced storage R&D uniting with world-class industrial design to create the slimmest way to carry 500GB of data. The Seagate Seven enclosure is made entirely of steel, not only to achieve the thinnest external drive, but also for a premium appearance inspired by a bare drive, the essence of storage. The superior experience is extended to the included USB 3.0 cable, a stylish, premium braided design instead of the standard cable found with most external drives. Since the drive is bus powered, meaning it draws power directly from the USB port, and does not require an external power supply, the Seagate Seven is perfect for those on-the-go situations. Push the limits of possible with the thinnest portable drive, Seagate Seven.
Seagate Seven STDZ500400 - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
Silver
82 mm x 122.5 mm x 7 mm
90 g
3 years warranty
500 GB
USB 3.0
82 mm
122.5 mm
7 mm
90 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
Seagate Dashboard
Apple MacOS X 10.6 or later, Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
1 x USB 3.0 cable - external - 45.72 cm
Enclosure Colour
Silver
Limited warranty - 3 years
Resources
The following resources are available for the Seagate 500GB Seven Ultra Slim USB 3.0 Portable Drive
