Seagate 2.5-inch SATA Hard Drive
Feature-rich, slim, lightweight style at price and capacity points that enable no-compromise designs for thin computing.
• Compatible with SATA 6Gb/s and 3Gb/s designs
• Backed by a 2-year limited warranty
Please note, this hard drive does not have the Secure Laptop Encryption (SED) feature
- Seagate Momentus Thin ST500LT012 - hard drive - 500 GB - SATA 3Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 5400 rpm
- QuietStep, Native Command Queuing (NCQ), Ramp Load, Advanced Format technology
- 70.1 mm x 100.55 mm x 7 mm
- 95 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 3Gb/s
- Buffer Size
- 16 MB
- Bytes per Sector
- 4096
- 70.1 mm
- 100.55 mm
- 7 mm
- 95 g
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 3 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- 0 °C
- 60 °C
- Shock Tolerance
- 400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
