Seagate 500GB Momentus Thin SATA 6Gb/s 5400RPM 16MB 2.5" 7mm
THE WORLD'S FIRST 7MM Z-HEIGHT, 2.5 INCH FORM FACTOR DRIVE
Quicklinx: 86TGWS00 Mfr#: ST500LT012
Seagate 2.5-inch SATA Hard Drive
Feature-rich, slim, lightweight style at price and capacity points that enable no-compromise designs for thin computing.
• Compatible with SATA 6Gb/s and 3Gb/s designs
• Backed by a 2-year limited warranty
Please note, this hard drive does not have the Secure Laptop Encryption (SED) feature
  • Enhanced durability
    Designed to withstand the rigors of daily use, the Seagate Momentus Thin features a shock tolerance storage of 1000 g @ 1 ms, ensuring your data remains safe even in the event of accidental drops or bumps.
  • Optimized for quiet operation
    The QuietStep technology incorporated into the Seagate Momentus Thin ensures a silent operation, making it an ideal choice for environments where noise levels are a concern.
  • High compatibility
    With its Serial ATA-300 interface and compatibility with Windows 7, the Seagate Momentus Thin offers seamless integration into most PC setups, ensuring a hassle-free upgrade or installation.
Seagate Momentus Thin ST500LT012 - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load, Advanced Format technology
70.1 mm x 100.55 mm x 7 mm
95 g
Microsoft Certification
Compatible with Windows 7
500 GB
2.5"
SATA 3Gb/s
Buffer Size
16 MB
Bytes per Sector
4096
70.1 mm
100.55 mm
7 mm
95 g
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
