Product
Seagate 4TB Ironwolf Pro 3.5" SATA 6Gb/s 128MB NAS Hard Drive
Quicklinx: CNXNWS00 Mfr#: ST4000NE0025
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£137.86 ex VAT
£165.43 inc VAT
For everything NAS, there's IronWolf. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also handle the high user workload rate in a high data traffic network.
  • Tough, ready, scalable
  • Grow your business NAS
  • AgileArray and the Power of IronWolf for your NAS
    IronWolf is built with AgileArray. NAS-optimized for the best NAS experience possible, AgileArray focuses on drive balance, RAID optimization and power management.
  • Dominate the media
    Build your home NAS media empire with IronWolf HDDs. IronWolf leads the class in storage capacity with drives as large as 10 TB, and the performance needed to run high definition content with your NAS. Store thousands of full-length HD films and even more photographs on your private server.
Seagate IronWolf Pro ST4000NE0025 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Hot-Plug Support, 24x7 availability, rotation vibration sensor, AgileArray
101.85 mm x 146.99 mm x 26.11 mm
680 g
5 years warranty
Bundled with
Seagate Rescue Data Recovery
4 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
146.99 mm
26.11 mm
680 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6 Watt (idle) , 6.7 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
ICES-003 Class B, NMB-3 Class B
Limited warranty - 5 years , Insurance - data recovery - 2 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (non-operating)
5 g @ 10-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: Seagate
Price Range Ex VAT: 100 - 150
