The Seagate Expansion desktop drive provides extra storage for your ever-growing collection of files. Add space for more files instantly, consolidate all your files to a single location, or free up space on your computer's internal drive for improved performance. Set-up is straightforward. Simply plug in the included power supply and USB cable and you are ready to go. It is automatically recognized by the Windows operating system, so there is no software to install and nothing to configure. Saving files is easy too: just drag and drop. Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backward compatible with USB 2.0 for additional system compatibility.
The easy-to-use storage solution
The Expansion external hard drive can be installed easily by plugging in two cords. You can start saving your digital files to this hard drive within seconds of removing it from the box. -
Adds storage capacity instantly
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity. The Expansion external hard drive helps remedy this situation by enabling you to free up storage space on your computer's hard drive.
- Seagate Expansion Desktop STBV4000200 - hard drive - 4 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 4 TB
- Interface
- USB 3.0
- Power Source
- Included AC adapter
- 118 mm x 179.5 mm x 37.5 mm
- 940 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 4 TB
- Interface
- USB 3.0
- 118 mm
- 179.5 mm
- 37.5 mm
- 940 g
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- OS Required
- Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Vista / 7 / 8
- Cables Included
- 1 x USB 3.0 cable - 1.2 m
- Localisation
- EMEA
- Limited warranty - 2 years
