- Seagate Constellation ES.3 ST4000NM0033 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, S.M.A.R.T.
- 101.85 mm x 147 mm x 26.1 mm
- 700 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 700 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 175 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 6.73 Watt (idle) , 11.27 Watt (read)
- Limited warranty - 5 years
- 5 °C
- 60 °C
- 5 - 90% (non-condensing)
- Vibration Tolerance
- 0.25 g @ 5-500 Hz (non-operating)
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 300 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.5 g @ 22-350 Hz
- Vibration Tolerance (non-operating)
- 4.9 g @ 10-500 Hz
