Product
Brand
Seagate 4TB Constellation ES.3 7200 RPM SAS-2 3.5" 128 MB Cache
Quicklinx: 91HWWS00 Mfr#: ST4000NM0023
Seagate Constellation ES.3 ST4000NM0023 - hard drive - 4 TB - SAS 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice, Protection Information (PI)
101.85 mm x 147 mm x 26.1 mm
700 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
4 TB
3.5" x 1/3H
SAS 6Gb/s
Buffer Size
128 MB
101.85 mm
147 mm
26.1 mm
700 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
175 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - 5 years
5 °C
60 °C
Vibration Tolerance
0.25 g @ 5-500 Hz (non-operating)
