Seagate 4TB BarraCuda Pro SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9X4WS00 Mfr#: ST4000DM006
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Spin Speed (rpm): 7200rpm
Select:
£133.38 ex VAT
£160.05 inc VAT
Versatile. Fast. Dependable. The extremely fierce hard drive. The uncompromising Barracuda Pro marries excellent storage capacity with high spin speeds for snappy performance and load times, when gaming or performing heavy workloads.
  • Amazing versatility
    Get the optimal out of your storage with Barracuda hard drives. From computers, full of photos and memories, to gaming PCs, that need more room to play, Barracuda grows with you.
  • Barracuda hard drives benefits
    Rock-solid reliability. Versatile mix of capacity and value to fit any budget. Multi-tier caching technology for excellent hard drive performance.
Seagate Barracuda Pro v6 ST4000DM006 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), PowerChoice, advanced format 512e
4 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), PowerChoice, advanced format 512e, S.M.A.R.T.
102 mm x 146.99 mm x 26.11 mm
680 g
5-year warranty
Bundled with
2 years Rescue Service Plan
4 TB
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
102 mm
146.99 mm
26.11 mm
680 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Power Consumption
7.45 Watt (read) , 9.65 Watt (random write) , 5.45 Watt (idle) , 10 Watt (random read) , 7.4 Watt (write) , 1.7 Watt (start)
Software Included
Seagate SeaTools
EN 60950, ICES-003, EN55024, EN55022 Class B, KCC, Directive 2004/108/EC, China RoHS, RCM, ASTM B845, FCC Part 15 J Class B, CAN/CSA-CISPR 22-10, ACMA, UL/CSA60950-1
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95%
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (operating)
0.25 g @ 350-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: Seagate
Price Range Ex VAT: 100 - 150
