Seagate 4TB 3.5" SAS 12Gb/s 7200RPM 128MB
Quicklinx: CWXDWS00 Mfr#: ST4000NM0125
Supporting the exceptional response times, Seagate's Enterprise Capacity 3.5 HDD enables the fastest data transfers thanks to the comprehensive advanced caching technology. Meet your storage workload requirements in the most efficient and cost-effective data center footprint available on the market today. With user-definable innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you have the control to tailor your bulk storage requirements for even greater improvements in lowering your total cost of ownership. When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate.
  • Maximum capacity and built for speed
  • World-class reliability meets high-capacity
  • Reliable, robust bulk data storage
    High capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads of up 550 TB per year, which is up to 10× the rated workload of desktop HDDs. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs. Choose from 12 Gb/s SAS or SATA 6 Gb/s interfaces for easy integration into existing platforms.
Seagate Exos 7E8 ST4000NM0125 - hard drive - 4 TB - SAS 12Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Super Parity, T10 Data Integrity Field (DIF), advanced format 512e, 24x7 availability, Advanced Write Caching
101.85 mm x 147 mm x 26.1 mm
680 g
5-year warranty
4 TB
3.5" x 1/3H
SAS 12Gb/s
Buffer Size
128 MB
101.85 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
226 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
2 x SAS 12 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
6.52 Watt (idle) , 7.74 Watt (active)
Software Included
Seagate SeaTools
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 1 ms
