Seagate 3TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Hard Drive
Quicklinx: CH04WS00 Mfr#: ST3000VX010
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk ST3000VX010 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
24x7 continuous operation
101.85 mm x 146.99 mm x 26.11 mm
610 g
3-year warranty
3 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.85 mm
146.99 mm
26.11 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.6 Watt (active) , 4 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
