An Easy-To-Use Storage Solution
Simple add-on storage
The Seagate® Expansion™ External hard drive by Seagate offers an easy-to-use solution when you need to add data storage to your computer instantly.
- Drag and drop file saving, right out of the box
- Fast data transfer with USB 3.0 connectivity
The easy-to-use storage solution
The Expansion external hard drive can be installed easily by plugging in two cords. Start saving your digital files to this hard drive within seconds of removing it from the box.
Adds storage capacity instantly
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity.
Can be installed in seconds
Seagate® Expansion® External hard drive features make it easy to start using this drive within seconds of removing it from the box:
- Simply plug in the included power supply and USB cable
- The hard drive is automatically recognised by the Windows operating system -- no software to install and nothing to configure
- Drag and drop to save files to the Expansion external hard drive
- Built-in power management automatically ensures energy-efficient operation
What's in the box?
- Seagate Expansion external hard drive
- USB 3.0 cable
- Power adapter
- Quick start guide
- 1-year limited warranty
The Expansion external hard drive can be installed easily by plugging in two cords. Start saving your digital files to this hard drive within seconds of removing it from the box. -
Digital photos, video and music files can tax your computer's storage, causing performance to decline as its internal hard drive fills to capacity. -
Seagate Expansion external hard drive features make it easy to start using this drive within seconds of removing it from the box.
- Seagate Expansion Desktop STEB3000200 - hard drive - 3 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 3 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- Included AC adapter
- 120.6 mm x 176 mm x 36.6 mm
- 950 g
- Localisation
- EMEA
- 2 years warranty
- Capacity
- 3 TB
- Interface
- USB 3.0
- 120.6 mm
- 176 mm
- 36.6 mm
- 950 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- OS Required
- Microsoft Windows 7 or later
- Cables Included
- 1 x USB 3.0 cable - external - 1.2 m
- Localisation
- EMEA
- Limited warranty - 2 years
