Seagate Laptop Thin HDD offers feature-rich, slim, lightweight style at price and capacity points that enable no-compromise designs for thin computing.
Seagate has purpose-built the Laptop Thin HDD to meet customers' demand for affordable, slimmer, fully functional computing solutions.
Seagate Laptop Thin HDD drives leverage current laptop drives in both material and product design to provide the world's first 7 mm 2.5-inch form factor drive. The result is affordable, thin storage for entry-level to mainstream laptops, high-end netbooks, thin ultra portables and slim-computing devices.
Opens frontiers for system designers
Seagate has purpose-built the Laptop Thin HDD to meet customers' demand for affordable, slimmer, fully functional computing solutions. -
Smooth migration to advanced format 4K
Laptop Thin HDDs include Seagate SmartAlign technology. This innovation helps you easily get all the benefits of the advanced format 4K sector standard - no utilities, no extra steps. AF drive migration happens automatically in the background. The drive's performance is not affected, and there is no need for time-consuming utilities required by other AF-enabled drives. -
Secure self-encrypting drive options
Seagate Laptop Thin self-encrypting drives deliver government-grade encryption without performance degradation - protecting your data where it lives. You get all the benefits of secure data encryption without the headaches. -
Enter Seagate ingenuity
Until recently, system integrators and OEMs had no choice but to limit their thinner, fully functional computing designs to high-end devices. The available hard drive options were either too costly, too slow performing or both. Seagate Laptop Thin HDD drives leverage current laptop drives in both material and product design to provide the world's first 7 mm 2.5-inch form factor drive. The result is affordable, thin storage for entry-level to mainstream laptops, high-end netbooks, thin ultra portables and slim-computing devices.
- Seagate Laptop Thin HDD ST320LM010 - hard drive - 320 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 32 MB
- Spindle Speed
- 7200 rpm
- QuietStep, Ramp Load
- 70.1 mm x 100.55 mm x 7 mm
- 95 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 32 MB
- Bytes per Sector
- 4096
- 70.1 mm
- 100.55 mm
- 7 mm
- 95 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 135 MBps
- Seek Time
- 11 ms (average)
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.8 Watt (active) , 0.65 Watt (idle)
- 0 °C
- 60 °C
- Shock Tolerance
- 400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
