Your basket is empty
Seagate 3.5 6TB SATA3 SV35 Series Hard Drive 7200RPM 64MB Cache 24/7
Quicklinx: BVNRWS00 Mfr#: ST6000VX0001
The Seagate Surveillance HDD addresses the need for high-resolution cameras and camera counts, and ensures cost-effective performance and durability in always-on surveillance systems.
Seagate Surveillance HDD ST6000VX0001 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Seagate Think Green, Advanced Format technology, 24x7 continuous operation
101.85 mm x 147 mm x 26.11 mm
780 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.85 mm
147 mm
26.11 mm
780 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
8 Watt (active) , 6.7 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
Limited warranty - 3 years
5 °C
60 °C
