Seagate 2TB Mobile HDD 2.5" 128MB SATA 6Gb/s
Quicklinx: C8CRWS00 Mfr#: ST2000LM007
Huge capacity in a thin lightweight design, the Seagate mobile HDD stores thousands of photos and songs or over a hundred hours of high-definition video. The mobile HDD has some of the highly advanced features and is ideal for traditional laptops, convertible and detachable storage, slim consumer electronics devices, helping to protect your sensitive data.
  • Compatibility and flexibility
    The mobile HDD works with SATA 6Gb/s and SATA 3Gb/s designs. This slim, high-performance HDD integrates easily. Drop in 2 TB without the weight of traditional laptop drives.
  • High areal density comes with quiet operation and excellent shock resistance
    The mobile HDD enables high areal density in a small form factor. The drive additionally performs operations very quietly and has advanced shock resistance.
Seagate Mobile ST2000LM007 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
QuietStep, Halogen Free, Ramp Load, advanced format 512e, shingled magnetic recording (SMR)
69.85 mm x 100.35 mm x 7 mm
90 g
Intel Next Unit of Computing 12 Pro Kit - NUC12WSHi3, 12 Pro Kit - NUC12WSHv7
2 TB
2.5" SFF
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
100 MBps
Seek Time
13 ms (average)
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
1.7 Watt (seek) , 0.5 Watt (idle)
RoHS
60 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 1 ms
