Seagate 2TB FireCuda 3.5" SATA 6Gb/s SSHD
Quicklinx: C8CWWS00 Mfr#: ST2000DX002
Form Factor: 3.5"
Type: Hybrid hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
More than 50 in stock
£76.13 ex VAT
£91.35 inc VAT
Play faster, work smarter. FireCuda drives meld the advanced SSD technology with a standard hard drive for a compact blend of capacity and faster speeds. FireCuda blends SSD technology and a standard HDD, resulting in performance similar to an SSD but with all the capacity you expect from an HDD. It's the perfect upgrade for gamers, creative professionals and PC enthusiasts. With a spacious storage, FireCuda makes deleting games and files - to free up disk space - a thing of the past. It is perfect for gamers and creative professionals who want it all, now.
  • Fast, big, durable
  • Ferocious performance
  • Richer gaming experience
    FireCuda SSHD delivers faster load speeds for non-stop performance and play. Save time with a drive that boots in seconds, not minutes. Get in the game significantly faster than traditional hard drives.
  • Superior storage
  • Efficient power savings
    Potentially lower your overall costs and increase your capabilities with the FireCuda. FireCuda 2.5-inch SSHD is performance-tuned to draw less power. Reducing power consumption and heat generation it helps increase system performance and improve durability, especially when playing games and running multiple applications.
Seagate FireCuda ST2000DX002 - hybrid hard drive - 2 TB - SATA 6Gb/s
Hybrid hard drive - internal - Native Command Queuing (NCQ)
2 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
101.6 mm x 146.99 mm x 26.11 mm
535 g
5-year warranty
2 TB
8 GB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.11 mm
535 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Seek Time
9.5 ms (average)
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.7 Watt (active) , 4.5 Watt (idle) , 0.75 Watt (standby) , 0.75 Watt (sleep)
Limited warranty - 5 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Form Factor: 3.5"
Capacity: 2TB
Brand: Seagate
Price Range Ex VAT: 50 - 100
