Seagate 2TB Enterprise Capacity 3.5 HDD V.3 SATA 6GB/s 7200RPM 128MB
Quicklinx: 8ZD7WS00 Mfr#: ST2000NM0033
The Seagate® Constellation® ES.3 enterprise HDD delivers the scalability that data centres need to meet their demanding growth of unstructured data reliably.
  • Highest-capacity enterprise drive, up to 4TB for maximum density server and storage solutions
  • Perfect for reliable, 24×7 bulk data storage
  • Predictable 7,200-rpm performance even in the most rugged multi-drive SAS or SATA environments
  • Best-in-class energy efficiency with low power and cooling requirements
Seagate Constellation ES.3 ST2000NM0033 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Low Halogen, Super Parity, S.M.A.R.T.
101.85 mm x 147 mm x 26.1 mm
635 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
635 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
175 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
5.17 Watt (idle) , 9.42 Watt (read)
Limited warranty - 5 years
5 °C
60 °C
5 - 90% (non-condensing)
Vibration Tolerance
0.25 g @ 5-500 Hz (non-operating)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
300 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
4.9 g @ 10-500 Hz
