Seagate 2TB BarraCuda Pro SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9X1WS00 Mfr#: ST2000DM009
Select:
  • 2TB
Versatile. Fast. Dependable. The extremely fierce hard drive. The uncompromising Barracuda Pro marries excellent storage capacity with high spin speeds for snappy performance and load times, when gaming or performing heavy workloads.
  • Amazing versatility
    Get the optimal out of your storage with Barracuda hard drives. From computers, full of photos and memories, to gaming PCs, that need more room to play, Barracuda grows with you.
  • Barracuda hard drives benefits
    Rock-solid reliability. Versatile mix of capacity and value to fit any budget. Multi-tier caching technology for excellent hard drive performance.
Seagate Barracuda Pro v6 ST2000DM009 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), PowerChoice, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.61 cm
550 g
5-year warranty
Bundled with
2 years Rescue Service Plan
2 TB
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
512
10.2 cm
14.7 cm
2.61 cm
550 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
195 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Power Consumption
6.29 Watt (read) , 8.43 Watt (random write) , 4.64 Watt (idle) , 8.41 Watt (random read) , 6.24 Watt (write)
Software Included
Seagate SeaTools
EN 60950, ICES-003, EN55024, EN55022 Class B, KCC, Directive 2004/108/EC, China RoHS, RCM, ASTM B845, FCC Part 15 J Class B, CAN/CSA-CISPR 22-10, ACMA, UL/CSA60950-1
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95%
Shock Tolerance (operating)
40 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (operating)
0.25 g @ 350-500 Hz
