The Seagate Backup Plus Ultra Slim portable drive is thin and features enhanced capacity possibilities and brings your important files and head out the door. High-speed USB connectivity offers Plug-and-Play functionality on your PC without the need of an external power supply. Run a one-click backup or schedule an automatic backup plan to protect your files in your Backup Plus portable drive at your convenience.
- Seagate Backup Plus Ultra Slim STEH2000201 - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Automatic backup
- Power Source
- USB bus
- Enclosure Colour
- Gold
- 76 mm x 9.6 mm x 113.5 mm
- 135 g
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- Automatic backup
- 76 mm
- 9.6 mm
- 113.5 mm
- 135 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- Driver, Seagate Dashboard
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
- Cables Included
- 1 x USB 3.0 cable - external - 45.72 cm
- Enclosure Colour
- Gold
- Localisation
- EMEA
- Limited warranty - 2 years
