Seagate's Enterprise Capacity 3.5 HDD enables the ultra-fast data transfers thanks to the comprehensive advanced caching technology. Meet your storage workload requirements in the efficient and cost-effective data center footprint. With user-definable innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you have the control to tailor your bulk storage requirements for even greater improvements in lowering your total cost of ownership.
Maximum capacity built for speed
Seagate's Enterprise Capacity 3.5 HDD enables the ultra-fast data transfers thanks to the comprehensive advanced caching technology. Meet your storage workload requirements in the efficient and cost-effective data center footprint. With user-definable innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, you have the control to tailor your bulk storage requirements for even greater improvements in lowering your total cost of ownership. -
World-class reliability meets high capacity
When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD, you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering your users a consistent and predictable response rate. -
Reliable, robust bulk data storage for a 24/7 world
High-capacity storage for multi-drive chassis requires predictable and reliable performance. The Enterprise Capacity 3.5 HDD is built to support enterprise-class nearline workloads. Clearly, the Enterprise Capacity 3.5 HDD can help to ensure that you meet your rigorous bulk storage SLAs.
- Seagate Exos 7E8 ST2000NM0135 - hard drive - 2 TB - SAS 12Gb/s
- Hard drive - internal - Halogen Free, Ramp Load, dual processor, PowerChoice, Humidity Sensor, Super Parity, T10 Data Integrity Field (DIF), advanced format 512e, 24x7 availability, Advanced Write Caching
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- 101.85 mm x 147 mm x 26.1 mm
- 610 g
- 5-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- 101.85 mm
- 147 mm
- 26.1 mm
- 610 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 226 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 2 x SAS 12 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 4.57 Watt (idle) , 6.34 Watt (active)
- Software Included
- Seagate SeaTools
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 40 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 1 ms
