Seagate 250GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive
Quicklinx: 7M38WS00 Mfr#: ST250DM000
Seagate desktop hard drives deliver optimal performance for every desktop computing need - from entry-level workstations to high-performance gaming systems. These desktop drives offer innovative technologies, super-sized capacities, low power consumption and blazing fast performance.
  • The power of one
    The Seagate Desktop HDD is the one hard drive for all your desktop applications. One drive for every need, supported by trusted performance, reliability and simplicity.
  • Seagate Desktop HDD: get what you want
    Count on Seagate to deliver the storage innovations that bring your costs down and crank your storage up.
  • Your no-hassle transition
    The Seagate DiscWizard utility makes the transition a snap.
Seagate Desktop HDD ST250DM000 - hard drive - 250 GB - SATA 6Gb/s
Hard drive - internal
250 GB
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Perpendicular Magnetic Recording (PMR)
101.6 mm x 146.99 mm x 19.98 mm
415 g
Microsoft Certification
Compatible with Windows 7
250 GB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
16 MB
101.6 mm
146.99 mm
19.98 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
125 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
50,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/4H
Power Consumption
6.19 Watt (active) , 4.6 Watt (idle) , 0.79 Watt (standby) , 0.79 Watt (sleep)
RoHS
60 °C
