Seagate 1TB NAS HDD SATA 6Gb/s 64MB Cache Internal Hard Drive
Quicklinx: BTN2WS00 Mfr#: ST1000VN000
Seagate NAS HDD
Ultra Reliable 1TB Drives for NAS, Servers & RAID
Put Your A-Team on Reliability
The Seagate® NAS HDD goes beyond the standard desktop drive and brings you high-capacity performance with robust 24×7 operation for your home or SOHO storage needs.
24×7 - RAID - Remote Access - Personal Cloud – Backup - NAS
• Perfect for 1- to 8-bay enclosures
• Dual-plane balance enhances drive performance in aggressive NAS workloads for better vibration tolerance
• 180TB/year Workload Rate Limit (WRL). Rest assured your heavier workloads can be managed easily.
• MTBF of 1M hours demonstrates mature robustness of drive family
NASWorks™ - Advanced Firmware for Specialized Workloads & Multi-drive Enclosures
Seagate NASWorks technology improves the reliability of NAS HDD by tuning drive features to deliver higher performance, superior reliability and interoperability with popular NAS enclosures such as Synology, QNAP, NetGear, ASUSTOR, MyCloud, D-Link, Drobo, LaCie, Lenovo, SimplyNAS, Thecus and, of course, Seagate!
• Save time - extended error recovery controls correct data without the need for full drive rebuilds
• Help reduce costs - low power consumption
• Maintain performance - dual-plane balanced motors minimises vibration
• Easy integration with NAS box suppliers
• Peace of mind with +Rescue Data Recovery Services
No One Has Your Back Like Seagate
Don't have an IT staff? No problem. Seagate offers affordable premium features that are integration-friendly, compatible, and deliver peace of mind.
• NASWorks optimises the drive for your NAS/RAID application
• RAID Recovery prevents the NAS from a full RAID rebuild if not needed.
• Dual-plane balance helps mitigate vibration
• 3-year +Rescue Service Plan can recover the data from your failed drive whether due to mechanical failure or accidental damage
- Fast and easy recovery process - data can be restored in 15 days or less
- Seagate leads the industry in data recovery with an approximately 90% success rate
Wrong Drive Got You Seeing Red?
Storage devices have evolved to meet data where it lives, and where it safely remains. However, content needs to be easily accessible - from anywhere, anytime. That means choosing the right drive for the job, and choosing reliable 24×7 access.
Choose the Seagate NAS HDD for:
• Collaboration and sharing at home or in the office
• Virtualisation and remote access in SMBs
• Multimedia server and storage for your home entertainment
• Backing up and keeping your digital content safe and sound over the long haul
Best-Fit NAS Applications
Designed for home and SOHO NAS desktop towers and rackmount enclosures (up to 8-bay), including NAS and RAID, the NAS HDD is a best-fit for these applications with 180TB/year.
• Backup and disaster recovery
• File and print server sharing
• Archival
• Remote access
• Virtualisation
• Private cloud storage
Seagate NAS HDD ST1000VN000 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Halogen Free, NASWorks, 24x7 continuous operation
101.6 mm x 146.99 mm x 19.98 mm
400 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
1 TB
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
146.99 mm
19.98 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
3.6 Watt (active) , 2.5 Watt (idle) , 0.8 Watt (sleep) , 0.8 Watt (standby) , 1.2 Watt (start)
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
