Product
Brand
Seagate 1TB Mobile 2.5" 7mm SATA 6Gb/s 128MB Internal Hard Drive
Quicklinx: C2JLWS00 Mfr#: ST1000LM035
Huge capacity in a thin lightweight design, the Seagate mobile HDD stores thousands of photos and songs or long hours of high-definition video. The Mobile HDD has some of the very advanced features. It is ideally suited for traditional laptops, convertible and detachable storage, slim consumer electronics devices, helping to protect your sensitive data.
Seagate Mobile ST1000LM035 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
5400 rpm
QuietStep, Halogen Free, Ramp Load, advanced format 512e, shingled magnetic recording (SMR)
69.85 mm x 100.35 mm x 7 mm
90 g
2 years warranty
1 TB
2.5" SFF
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
69.85 mm
100.35 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
100 MBps
Seek Time
13 ms (average)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
1.6 Watt (seek) , 0.45 Watt (idle)
RoHS
60 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 1 ms
