Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
Quicklinx: 8XSLWS00 Mfr#: ST1000DX001
Buy a Seagate Desktop SSHD today and receive a Dying Light Season Pass. Once you have bought your product, email duncsdeals@dabs.com with your Name, Email Address and Sales Order Number and you will receive a follow up email within 48 hours with your code.
Performance. Capacity. Affordable Price.
The wait is over for a solid state hybrid drive in a 3.5-inch form factor. The Seagate® Desktop SSHD delivers SSD-like performance and massive capacities at an affordable price. Don't waste time and money on a dual drive solution to get the high performance and capacity you demand for:
  • Desktop PCs
  • Workstations
  • Direct-attached storage (DAS) devices
The Seagate® Desktop SSHD is here with breakthrough technology that identifies and stores to flash only your most frequently used data. You can boot up and launch applications faster while still having the massive capacities you need for everything else. Choose performance and capacity with 8GB of MLC NAND flash and up to 2TB of HDD capacity. 3-year limited warranty.
Why choose the Desktop SSHD?
  • Simple. An all-in-one storage solution
  • Performance. SSD-like performance to give you the boost you crave
  • Capacity. The capacity you need--up to 2TB
  • Price. An affordable price that makes sense
  • The first solid state hybrid drive (SSHD) in a 3.5-inch form factor
  • Boots up and performs like an SSD1
  • SATA 6Gb/s with NCQ for interface speed
  • Faster than a traditional HDD1
  • All-in-one design for simplicity and ease of installation
  • Installs and operates like a standard hard drive: cross-platform, no drivers or additional software required
  • Massive 1TB or 2TB capacities combined with SSD-like performance1
  • Backed by a 3-year limited warranty
Solid State Drive Technology Inside Your SSHD
SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate's Adaptive Memory ™ technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
Get it all - desktop speed and capacity.
With SSHD technology, there is no need to trade capacity for high performance. The Seagate® Desktop SSHD is available in 1TB and 2TB capacities, giving you plenty of space for all of your digital content. Store up to 1,000 video games, 2,000 hours of video, 500 HD DVDs, 640,000 digital photos, or over 33,000 hours of mp3 music files.* *Quantitative usage examples for various applications are for illustrative purposes. Actual quantities will vary based on several factors, including file size, file format, features and application software.
Affordable and reliable SSHD for your desktop
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You'll be surprised at how little you have to pay to get SSD-like performance in your desktop system.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Easy, Low-cost HDD Desktop Upgrade
SSHD provides a great way to breath new life into an older desktop computer.
  • Get performance you never thought possible from your old system
  • One of the most cost-effective ways to increase the performance of your system.
Spec
  • Capacity: 1TB
  • NAND Type/Size: MLC/8GB
  • Interface: SATA 6Gb/s NCQ
  • Cache 64MB
  • Average Data Rate, Read, Avg All Zones up to 156MB/s
  • Average Data Rate From NAND Media up to 190MB/s
  • Operating Temperature: 0°C to 60°C
  • Solid State Drive technology inside your SSHD
    SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate Adaptive Memory technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
  • Affordable and reliable SSHD for your desktop
    SSHD fuses the strength of SSD and HDD into one affordable and powerful hybrid drive. You'll be surprised at how little you have to pay to get SSD-like performance in your desktop system. And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Seagate Desktop SSHD - hybrid hard drive - 1 TB - SATA 6Gb/s
Hybrid hard drive - internal
1 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
3.5" x 1/4H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Native Command Queuing (NCQ), SSHD
101.6 mm x 146.99 mm x 20.17 mm
400 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
1 TB
8 GB
3.5" x 1/4H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
20.17 mm
400 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average)
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/4H
Power Consumption
5.9 Watt (active) , 0.9 Watt (idle)
Limited warranty - 3 years
60 °C
8XSL StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £75.59
Resources
The following resources are available for the Seagate 1TB Desktop SSHD 7200RPM SATA 6GB/s 64MB 3.5" 8GB SSD Cache
